TwinTurbo.NET: Nissan 300ZX forum - Possibly battery cable(s)? They might be aged to the point
LitlElvis
on March 16, 2023 at 11:34 AM
Intermittent starter grinding after 3 starters, new flywheel
posted by tommyp98
on March 14, 2023 at 01:14 PM
they're not allowing enough amps to the starter for optimum performance.
tommyp98
13:14:38 03/14/23
Re: Intermittent starter grinding after 3 starters, new flywheel
itsa300zx
13:57:12 03/14/23
I'm dealing with exact same issue
GrecV2
09:15:09 03/15/23
Re: I'm dealing with exact same issue
tommyp98
06:58:53 03/23/23
From Bernie...
GrecV2
05:22:30 03/26/23
Thanks. (n/m)
00:12:16 04/09/23
Here:
00:37:32 04/09/23
Possibly battery cable(s)? They might be aged to the point -
LitlElvis
11:34:52 03/16/23
Enough corrosion on the cable would lead to significant
MixManMash
17:53:07 03/16/23
Low volts on trigger wire will damage solenoid.
mrchips
08:28:24 03/26/23
Thanks all, ordering a solenoid and will check wiring/cables (n/m)
tommyp98
19:09:06 03/16/23
zunit32
16:24:02 03/25/23
